We recently made an architectural change to our product. We moved processing of data from a job to a service broker. We don't see any of the resource utilization of the service broker in Ignite. How can I get this data included?
Hi jason.triplett,
Service Broker is considered a background process, here is the 'quickpoll where clause' that you will need to add in Ignite to get all of the background processes.
AND s.spid like '%'
UNION ALL
SELECT s1.loginame, db_name(s1.dbid) name, s1.hostname, s1.program_name, s1.sql_handle, s1.stmt_start, s1.stmt_end,
s1.spid, CONVERT(smallint, s1.waittype) waittype, s1.lastwaittype, s1.ecid, s1.waittime,
CONVERT(varchar(64), s1.context_info) context_info , s1.blocked , null
FROM master..sysprocesses s1 WITH(NOLOCK)
WHERE s1.spid < 50
AND s1.status != 'sleeping'
AND s1.cmd<>'AVAITING COMMAND'
AND s1.lastwaittype NOT IN ('SLEEP_TASK')
To add:
In Ignite > Options > Advanced Options > check 'support options' box > choose database (lower right screen) Look for parameter: QuickPoll Where Clause and add the code above. Please let me know if this doesn't help, if the issue persists please send an email to support@confio.com and we'll take a look for you.
Here's what I'm using since we upgraded to 9:
AND s.spid LIKE '%'
union all
SELECT s1.loginame ,DB_NAME(s1.dbid) NAME ,s1.hostname ,s1.program_name ,isnull(r.sql_handle, s1.sql_handle) as sql_handle ,isnull(r.statement_start_offset, s1.stmt_start) as stmt_start ,isnull(r.statement_end_offset, s1.stmt_end) as stmt_end ,s1.spid ,CONVERT(SMALLINT, s1.waittype) waittype ,s1.lastwaittype ,s1.ecid ,s1.waittime ,CONVERT(VARCHAR(64), s1.context_info) context_info ,r.wait_resource ,s1.blocked ,r.plan_handle ,r.statement_start_offset ,r.statement_end_offset ,r.start_time ,r.query_plan_hashFROM master..sysprocesses s1LEFT OUTER JOIN sys.dm_exec_requests r ON r.session_id = s1.spidWHERE s1.spid < 50 AND s1.STATUS != 'sleeping' AND s1.cmd <> 'AWAITING COMMAND' AND s1.lastwaittype NOT IN ('SLEEP_TASK')
Is there an update for version 10, or does the Version 9 code still work?
Should still work. Our quick poll methodology did not change.
mandevil-
What about in version 11.1.457? Is there an updated version of this? Or is there a different way to possibly collect Service Broker data? Thanks!
No update to the quick poll for specific collection. You'll have to still use the workaround.
