How about just a link for those of us that aren't allowed to run code inside the mail client?
Or...
Interface ${NetObjectName} on ${NodeName} received at ${Interface.InPercentUtil}% of its utilization, which triggered this alert. ${SQL:SELECT REPLACE(REPLACE(Macro, '$$Password$$', ''),'$$User$$', 'Admin') FROM NetFlowAlertMacros WHERE ID='OutWebMailInterfaceDetailsLink'}
...but then it will email your password
Is it javascript that is causing the problem?
That's my guess but ActiveX, etc.. would also cause an issue. We don't even allow downloading of pictures by default. We're a Health Insurer.
I'm trying to get it to just send me a link but haven't had any luck yet.
Try using the "Send an E-Mail / Page" action and include the following in the message:
Interface ${NetObjectName} on ${NodeName} received at ${Interface.InPercentUtil}% of its utilization, which triggered this alert. ${SQL:SELECT Macro FROM NetFlowAlertMacros WHERE ID='InInterfaceDetailsLink'}
Hope that works for you.
Link didn't make it into the message body.
Nevermind, don't think netflow was on that interface..
Or...Interface ${NetObjectName} on ${NodeName} received at ${Interface.InPercentUtil}% of its utilization, which triggered this alert. ${SQL:SELECT REPLACE(REPLACE(Macro, '$Password$', ''),'$User$', 'Admin') FROM NetFlowAlertMacros WHERE ID='OutWebMailInterfaceDetailsLink'}...but then it will email your password
Good enough for now.
Hi All,
I know that this is an old post, but I have a question about the solution here. I tried this out and I get the email with the URL. However, when I follow the link it takes me to a page with a 404 error as seen here:
Does anyone know why this is? Here is the URL that got generated (hostname was correct, but I changed it):
http://MyHostName:80/Orion/TrafficAnalysis/Utils/AlertRedirect.aspx?InterfaceID=4&UtcTime=2013-03-18T16:03:40.880&Direction=Egress&WebByMail=true&Utilization=7&AccountID=Admin&Password=&AccountID2=Admin&Password2=&NetFlowEnabled=true
Any help would be great!
