i would like to integrate Kiwicattools with the following:
1- Hwaui firewall
2- IPS OF IBM
3- SEMANTIC PRODUCT
4- WINDOWS SERVER
thanks,
You'll need to configure those devices to send Syslog to the IP address of your Kiwi Syslog Server. For 1-3, you're going to need to consult the vendor documentation for how to enable Syslog.
For 4, you can use the event to trap forwarder built into Windows (evntwin.exe). This requires that the SNMP service be installed on the Windows server. Or, you can use the free Snare utility: www.intersectalliance.com/.../index.html
Dear,
thank you for your replay, but i meant to integrate these dvices with kiwicat tools backup configueration.
is there any way to do it by writing custom script?
If they're not supported out of the box, yes, you'll need to write a custom device script.
can you please show me example how to write a script?
Hi obozidan,
The link below will take you to the section of the help file which details this.
http://www.kiwisyslog.com/help/cattools/dev_creatingcustomdevice.htm
Hi
If not Kiwi should be able to create a custom script for you. They have done this for our Company before with Radware devices. They may need acccess to the device in order to do this. Best bet is to send a support request for the device you want added and see what they come back with.
Jay
