We are looking at using LEM to capture Microsoft Failover Clustering events from the Windows Application Event log. Are these logs that LEM will be able to capture?
To chime in here - some of the logs are covered in a very generic way, just to get the most common data in to LEM. Effectively, there's some generic normalization that makes it easier for you to get data in without having to have a connector built.
However! You can submit requests to either a) create a connector for that data source (if it's a lot of unique events) or b) update our application log connector to include additional (useful) information. We'll need an evtx sample and some idea of what you're looking for.
Somebody... anybody?
Do you have any idea what the Microsoft ProviderSID might be for these events?
The LEM has a connector for the Windows Application log. It's not part of the default set that the LEM assigns to a connector when it detects a Windows platform, so you may need to add it to the agent for your server(s).
Now, will it read the app logs correctly? I'm not sure, but getting the connector up and running would be the first step to finding out.
I am in the midst of testing and what I have learned so far is as follows...
If you change the connector to get nDepth and Alert, do you see the whole message in the nDepth Raw Log Search? Would that work for what you need?
Good question, is there some specific way to search the Raw Logs? Is this the case where I need to go through the process indicated HERE?
An example of a received event is as shown below, the actual event in the Windows Event Log has a lot more data. Is it normal for LEM to truncate a bunch of information out of the log?
Right, you'll have to run through that process to get the LEM prepared to collect the raw logs or message cores.
Next, the relevant connectors need to be set to send raw data to the LEM. Either of these options will do it, but if you still want the normalized data, you should pick Alert, nDepth.
Last, you need to tell nDepth to search the raw messages. This toggle has moved around in different iterations of the console, but you'll want the mouse-over to say "Log Messages." In 5.6 and 5.7 it's in the top right corner near the Play button.
For the normalized alerts, yes. The LEM tries to reduce noise and improve the readability by trimming and formatting data to meet the needs that customers have shared with us. The ability to capture raw logs means you can always get all the data, but it's not the default selection.
Ah, ok, that makes sense!
Thanks! What I found odd was how the information was truncated. I thought (apparently incorrectly) that data from the log that wasn't normalized would be added to the ExtraneousInfo field.
