I want to generate a report to show " sh mac add " output of all the nodes on solarwinds NCM v.7.3.2 .
Please help if possible.
msalipong You should be able to setup a NCM job to "execute a script". Within that job, there should be an option to save output to a file. I do this every night for a "show dhcp clients" command, across 600+ DSLAM blades. This generates a single list of IP/MAC addresses being used by our DSL customers. Our techs are able to search that list, making it easier to track down customers/issues.
msalipong Something like that should get you what you're looking for.
Let us know how it goes.
Thank you,
-Will
Will
Can you explain the path link ?
Do web enable the data that way ?
sja I'm not certain of the intended purpose/outcome of using that option, however, when I use it, it creates a single file, and dumps all of the results of the executed command(s)/script from the NCM job, from all of the devices, into that single file. This allows me to easily build a page of command results, which can be searched/viewed by my NOC/Support teams. It allows them to go to a single web page, 'CTRL-F' to find the IP (or whatever it is they are searching), and find the results. Previously, I had created a separate config type to download (running, startup, dhcp), and then had them do a config search, via the NCM link. However, building the page allowed me to provide a single place to view, and I didn't have to worry about giving folks more NCM access than they needed/should have.
In order to get the settings to work, I had to create the same path/folders, with appropriate permissions, on all of my APEs too. Afterwards, it all just seems to work.
Okay..
Is it something you run many time every day?
If not you could run it as a job ...
Like that I backup to the DB Juniper Hardware ..
That make that data "search enable"
Juniper Devices-1.3.6.1.4.1.2636 with show chassis hardware
