Upgraded to 8.5 and my node list isn't correct. We sort by 3 fields. Some of the fields is not showing up properly..its pretty random. I check custom property editor and the fields are there.Ideas?BB
I'm not sure if you have to still do this, but have you updated the Schema's?
Sounds very similar to this post....
Yes, there seems to be a bug around sorting by custom properties. I understand that you don't want to post screenshots. If you want to send us the details of the bug with screenshots, please open a Support ticket. It would help us diagnose the issue.
Denny,I opened case 17225 on Monday and have yet to hear from any one. I have the screen shot ready to be sent in. As a side note it would be really nioce if we can attached files to the tickets when we submit them instead of waiting for an email back asking for the same information.
Also...I opened 17804 this morning because I noticed in the node list that alot of my devices have a blinking grey circle next to them. When I click on the device I don't see any apparent issues. Screenshot attached.
Thanks Bryan for pointing this out- I tracked down case 17225 and it was closed because the tech was under the impression you had resolved the issue via a call-?
anyway 17804 will be looked at by DEV-
thanks
Thanks Bryan for pointing this out- I tracked down case 17225 and it was closed because the tech was under the impression you had resolved the issue via a call-?anyway 17804 will be looked at by DEV- thanks
WHAT??? Closed? No one called me about it, nor did anyone email me about it. Please re-open that ticket for me. Another suggestion is when your support closes ticket it would be nice the requester get an email that it's closed with a reason. BB
Bryan,
You should definitely have been sent a note. That is normal procedure. The support rep made a mistake. We are re-opening that ticket.
Apologetically,
Denny
Bryan, You should definitely have been sent a note. That is normal procedure. The support rep made a mistake. We are re-opening that ticket. Apologetically,Denny
Sent a note that it was closed? Hmmm....I don't recall evey getting a close email. Maybe have your system send out a generic email like you do when you open tickets.IE "Case # XXXX Closed: Issues with XXXX"
When your support person marks it closed this could automatically be sent out so we know.BB
I would suggest adding the list of issued support tickets by the user to the customer area on Solarwinds web site. The list could contain ticket number, dates, subject, status, assigned department/person (?!) ... and would be visible only to the customer.
Best regards.
Tomaz
Denny, I have the same issues. Don't want to open redundant tkts if your team is already working this so could you please post back here with re/solutions?
These are issues that will be address in a service release. Everyone will be notified when that's ready.
