I want to evaluate the new VOIP monitor tool but there is no topic int he documentation explaining or referring to the configuration you need to do on your VOIP routers !
That's because the configuration is automatically done by the VoIP module itself. You just need to make choices in the settings:
www.solarwinds.com/.../wwhelp.htm
I assume that at a certain point you get a login prompt to configure your cisco device ?
Because I don't have a clue how the installation procedure will be able to access our password protected routers to make the necessary changes
The VoIP Monitor will do all the changes via a SNMP rw community. So you have to establish a rw community on the device.
Just read it in the manual ( RTFM )
But from a security point of view I'll be adding a weakness in our security framework.
I can configure an ACL for this but does it only need to configure the device once or does the system needs to update the configuration on a regular basis ?
VoIP Monitor will need to update the configuration on a regular basis to maintain the IP SLA operations. When an IP SLA operation expires or the device is rebooted, VoIP Monitor will create new IP SLA operations automatically.
Can it use V3 SNMP?
