Is there any reason to have a copy of the Engineer Toolset on our Orion server? We would just need them client side to be able to take advantage of the tools from the Orion page, correct?
The only reason I could see would be if you're viewing Orion from the web server.
I thought the Toolset would need to be installed ON the Orion polling server in order to be able to integrate the tools through the Orion website. No?
You need to have a copy of the toolset installed on each machine you want to launch the tools on from the Orion web interface.
So, as long as I can gain remote access to the Orion server, I can have the Toolset installed on say, my laptop, rather than having to have them on the server exclusively.
Is this still true if the Orion server additionally has Cirrus installed?
