Your answer lies within, Grasshopper ;-)
Yes, that's what I meant to say... Ordering of columns within the tables... All you have to do is right-click on a table from within Enterprise Manager (ex. Nodes), then select "Design Table". From within this view, you can select the column to be moved by clicking on the little box beside a column that you want to move, then simply drag to where you want it.We use custom proprties quite extensively, and having them in some logical order makes things much easier. Oh, and I believe it has to be the Standard or Enterprise version of SQL. If you're simply running the MSDE version on another server, I'm not sure that it has the ability to do this.
I would like to get a little more clarification on this process, or request if anyone has written any custom resources in the last 2 years.
I currently have a similar problem in which I need to scroll all the way right to see the newest and sometimes most needed custom properties. After lots of fighting with the Thwack search feature (its very lacking) I came across this post.
Any help would be greatly appreciated.
There are some in the Content Sharing Zone-
Thank you.
Fantastic. I will be trying this out sometime this week. Thank you for pointing me in the right direction.
********************EDIT*********************This worked great. Much easier now that I can organzie them to match the business importance.
**Side note** Saving changes will not effect any pollers that you have running. (At least in my case)
