Can I upgrade NPM to 10.6 and continue to run SAM at 5.5.0 without any issues?
Thanks in advance for any feedback!
Why would you not want all of the awesomeness that is SAM 6.0?
SAM 6 would be required due the Core platform version dependency.
Oh, don't get me wrong I WANT SAM 6.0, I just don't like to update multiple things in a single maintenance window. I was going to do one and then the other a week later. I had a feeling that they would both need to be updated though due to the changes in Core. So is the process still the same in that I should update in the following order...
NPM Platform
NPM Addt'l Poller
NPM Web Server
SAM Platform
SAM Addt'l Poller
SAM Web Server
You got it sir.
Awesome, thanks Rob!
We are also running NCM 7.1.1, am I required to upgrade that as well or can I do that at a later date?
Byron,
7.1.1 should work just fine with the version of core that ships with 10.6.
Awesome, thanks again Rob!
