I upgraded npm but get this error on netflow when added my wlc. I also do not see any stats
is receiving flow data from unmonitored WLC node
Hello Marnell,
I believe these KBs will help you resolve your issue:
Unmonitored NetFlow interface - SolarWinds Worldwide, LLC. Help and Support
Unmonitored interface automatically added - SolarWinds Worldwide, LLC. Help and Support
I already had the options checked. Still not seeing data from the WLC like I do on my ASR. Can I use the same port 2055 or should I use a different port?
You still use port 2055. Did you also set the "Netflow Monitor" under the WLANs, QoS tab?
yep
What model WLC are you using?
cisco 5500
I was wondering if it was a 5508 or 5520? The 5508 does not support the fields that Solarwinds is expecting to receive within the Netflow template.
I was able to get Netflow working on a 5520 by selecting "Client App Record (Better Performance)" under Netflow Monitor. I wasn't able to get any data using "Client Source and Destination record (Higher visibility).
Yea they are all 5508. Would this a cisco issue or something SW could get working with a new patch or update?
It looks like a Cisco issue. NBAR2 and Flexible Netflow for Cisco WLC 5508
