Wow... here we are, 6 years later, and I have the same problem. Can we please make this column resizable? The divider even allows you to move it -- until you release the mouse button, then it snaps back into place at 56 columns. Ugh!
Hi Sol--
What version of NPM are you running?
M
We're running NPM 10.1.1.
We have the same issues in NPM 10.2.
It is impossible to bulk edit intefaces as the column width is not wide enough to view the full interface names.
This must be such an easy thing to fix yet it still has not been done.....
I am nervous about exporting/importing whilst people have access to the console as it will take a while to do the editing I need and someone could make other changes during that time.
Why have a width restriction on the column????
i would near guarantee that SW are planning to retire the CPE and roll it into the website... i would say that when this happens, it will be the end of the product line and it will be time to move on LOL
We're in need of this as well, especially when dealing with Interfaces! There is no way to see which interface we're dealing with because the name scrolls past the hard limit of the non-resizable column. When will there be some way to work with this??
This won't happen on the Win32 app. They are shelving the app and moving it to the web front end. I would imagine this is something you will be able to do on the web front end without an issue.
So since we keep coming back to the elephant in the room, let me state it outright: WHEN will this be incorporated into the Web frontend? There has been at least one major update of the software and several patches since the request was originally made and it's still not in the Web frontend.
10.4 beta is running now and moving the custom properties editing is part of it.
