Can or does AppInsight for SQL monitor individual DB memory utilization, or can we only see overall server memory utilization?
32bit WMI is limited to returning processes memory values up to 4GB. To resolve this, edit the AppInsight for SQL application and change the "Platform to run polling job on" from "x86" to "x64". This will then return the correct value for 64bit processes which utilize more than 4GB of RAM.
AppInsight for SQL will reflect each Database Instances memory utilization on the Application Details view. You can also see the server's overall memory usage on the SQL Servers Node Details view.
Are you able to show a screenshot or something of where exactly the instance memory is at? I have been looking all over and can't seem to find it.
I found that now, but my Physical Memory Used is also only showing 4GB. The sqlservr process on my server is using ~29GB of RAM. Is SolarWinds unable to see more than 4GB of used memory?
Great, that was it. Thanks!
