Actually, how DO you create new tabs? I am using 11 and cannot see where to do this?
To the best of my knowledge there is not. The tabs at the top of Orion are set by the developers and reflect the modules that are installed. To help, Solarwinds created the subtabs at the right. You can customize any view and add subviews on the right providing many more options.
Thanks for all your information.
Please could you let me know how can i change the logo in NPM for company from default solar winds?
Change Logo:
Setting -> Web Console Settings -> Site Logo URL (place the image you want to in the correct folder and update this field accordingly)
Is there a way to add tabs to the menu bar in NPM
YES you can, Settings -> "Customize Menu Bars" under Customize Navigation & Look . Create a menu bar and wrt to your tabs, you will see a "ADD" button at the bottom, check the screen shot below - you can create new TABS using this and append the same to your menu bar and then link it with the account your require.
I read the question differently "Actually, how DO you create new tabs?". If you edit an account you get given so many Tabs that you can customize,
what I cannot see is how to add an additional one there. Closest I can get is to leave the main ones as default and use a newly created Menu in the
"Home Page View" of account settings, not really creating a Tab though ... anyway.. one way or another, there be some answers
You can, new custom menu item will let you do that. What you need to do is create a new view under managed views and using new custom menu item you can link that view you created as a tab onto your menu bar (we will need to provide the URL of the view ). And then in an account you can use the menu bar you require accordingly. TABS are nothing but different views in your environment.
Hi Vinay,
i have same question as Rhidian, but i didnt get your answer.
i will repeate it in different way. In NPM there is several default tabs:
Home,Network,Voip.....(depends on your installed modules).
what i want is, to have new custom Tab as "Home".. is it possible ?
H.
It's not possible to add custom tabs like HOME, NETWORK, etc. Only the views and the collection of views (menu bars) can be customized.
this is not possible at the moment if you want all the default menu's and you want to add a new one.
