I know that you can't build an interface alert and use node details in the trigger conditions and vide versa, can you have an interface alert and use node details in alert supression?
I have interface alerts and node alerts that notifiy me when the network status is down. The node alert notifies me when my router goes down and the interface alerts me if the WAN interface goes down which would also cause a network outage. I just had a router go down and I got both alerts. The interface is down because the node is down. Can I put a supression on the interface alert that says to supress the alert if node status is up? If not, any suggestions so I'm not getting 2 alerts for the same thing? I wish SW would let you create an alert using interface and node details, is that on the roadmap?
Christina
