Looking for information beyond the basic barebones type of field schema, something that describes the utility for anything beyond the obvious fields.
In general, we are incrementally improving the documentation piece by piece.
In regards with the properties you specifically referred to, here are the descriptions in context of Orion.Netflow.Flows* entity types (in addition to the documentation provided in NTA 4.0 Entity Model · solarwinds/OrionSDK Wiki · GitHub):
There's more information on the github wiki (Home · solarwinds/OrionSDK Wiki · GitHub) and sean.martinez posted some great info on thwack: Orion SWQL, Thwack! Now I got it.
I've seen much of that information which deals primarily with documenting the schema and accessing the raw data, but I'm looking for actual details of what values the fields represent. For example, in Orion.Netflow.Flows what does Weight and ObservationFrequency represent?
Thanks very much
Is there any documentation describing the functions of tables and its columns with foreign reference. Any help would be appreciable.
So you can see in admin Guide for modules.
Sem mais.Claudia França
2017-05-05 11:43 GMT-03:00 six9three9 <communityteam@solarwinds.com>:
<thwack.solarwinds.com>Is there a data dictionary for the Orion databasereply from six9three9<thwack.solarwinds.com/.../six9three9in Orion SDK - View the full discussion<thwack.solarwinds.com/.../364361
