Hi All,
i want configure netflow on cisco 837 and 877 for the netflow analyzer. my router wouldnt recognise the ip route-cache flow on the router on the interface on fastethernet. please help
hi all,
by rebooting the router and removing the node from npm server the data came through. but its not constant though. i have to reboot the router to get the data every time?any idea?
Have you tried the netflow configurator?
http://www.solarwinds.com/products/freetools/netflow_configurator.aspx
Is it responding to the ip flow-cache and ip flow-export commands?
i am just downloading the configurator. do think i need to do it on vlans as its a site to site vpn...
hi
it didnt work..comes up with error" a connection couldnt be made to the specified device. ensure you have the network access to the device and credential are correct". all the info is correct still its giving error.
Can you connect to the Cisco devices from the machine you installed it on? If you connect in manually, can you run the ip flow-cache command?
This should work on the 877s. The 837 will require NetFlow v9 config using ip flow ingress and ip flow egress commands at the (config-if) level. Make sure to configure netflow at the (config) level with
thanks for the replies. i have a doubt now. router is 877 and its a site to site vpn and we have the vlans on the router. so ip route-cache flow command should be excuted on the vlans or on the fastethernet physical interface. on fe0 the ip route-cache command doesnt work. but on the vlan interface the command did work. please advise
toms003,
Try this...
Global commands:
ip flow-cache timeout active 1ip flow-export source Loopback1 (or the interface you want reporting to NTA)ip flow-export version 5ip flow-export destination <NTA IP> 2055ip flow-top-talkers top 20 sort-by bytes
I typically don't use "ip route-cache flow," instead, try using "ip flow ingress" or "ip flow egress" on the physical interfaces. All traffic flows through the physical interfaces, and you can capture all the conversations while limiting the resources necessary for collecting the data.
Here's the Cisco doc for reference, you probably already have this: http://www.cisco.com/en/US/docs/ios/12_1/switch/configuration/guide/xcdnfc.html
Hope this helps.
Dwyane
Hi Dwyane,
thanks.the main problem is my cisco router 877 wouldnt recognise the ip flow ingress or regress or route cache command on fe2 or fe0 which are the 2 physcial interface. the ip commands listed are below.there is no ip route cache or ingress listed.pls see belowinterface IP configuration subcommands: address Set the IP address of an interface ddns Configure dynamic DNS dhcp Configure DHCP parameters for this interface header-compression IPHC options rsvp RSVP Interface Commands rtp RTP parameters vrf VPN Routing/Forwarding parameters on the interface
Hi Toms,
Not sure if you got this working, but I am using a Cisco 871, and can confirm that the Interface will take the ip flow command.
However the interface must also be configured. For example on one of our FA interfaces, it is just setup as a Trunk port to a switch. On that interface, the ip flow command is invalid. On Interface 4, which we have configured as the WAN port via PPPOE, the ip flow command works.
You may want to look at how the interface is configured, to see if it will even report Netflow data.
Hi hutcha,
Thanks. we have used switch port command on the interfaces,so we have vlan1 configured for the data. .ie fa0 as vlan1. so i have configured the netflow command on vlan1. the command wouldnt recognise on fa0. on vlan1 its taken all the commands and when i look at the show ip flow and cache its giving the desired data but its not reaching the nta server(nothing is blocking the port) so dont know what is happening.
A couple of things you can do at this point.
Do a sho ip flow export on the router and make sure the IP address and port of the NetFlow collector are correct. Also check that the output indicates packets are being exported.
Next take a packet capture (Wireshark) from the Orion/NTA server interface and see if cflow packets are being received from the router. If they are then look at the indicated interface number and see if it is listed as interface 0. That could be an issue. If the sho command indicates that packets are properly being exported but Wireshark sees no cflow then something along the path to the NPM server is eating them.
HI Mcbridea,
thanks for the reply.
The router is showing its exporting. but analyzing the file capture, cant see anything recieved on the netflow server on that port.nothing is blocking that port though.
router#sh ip flow exportFlow export v5 is enabled for main cache Export source and destination details : VRF ID : Default Source(1) 10.xx.xx.1 (Vlan1) Destination(1) 10.xx..xx.14 (2055) Version 5 flow records 151506 flows exported in 20577 udp datagrams 0 flows failed due to lack of export packet 74 export packets were sent up to process level 0 export packets were dropped due to no fib 0 export packets were dropped due to adjacency issues 0 export packets were dropped due to fragmentation failures 0 export packets were dropped due to encapsulation fixup failures
I have seen where robooting the router kick off the flow export.
