Is it possible to have a facility to be able to rename unknown devices with your own Vendor names, including ICMP only monitoring devices
Hi Bryantc496,
If there is a device which is unknown and we are not aware of it, i would recommend you to add to this thread
Thanks!
AK
Its more for ICMP only devices which I want to name the vendors for
Hi Bryantc,
I think custom properties will quit you better in this kind of scenario
feel free to have a look, you can customize a new properties called custom_vendors or something near.
www.solarwinds.com/.../CustProp.html
Hi bryantc496,
In addition to the information that was provided by aniki84, you might want to refer to this KB that was set up for just the purpose that you are at: support.solarwinds.com/.../ProblemDetail.cfm
HTH.
+1 on this. My contention comes with the ICMP only - and custom properties wont really help when the page shows unknown type
Hi njoylif,
Interesting, i suppose that is one of the resource reporting using the vendor from the nodes table,
have you tried using report writer? you can transform a report result into a resource by using report from report writer
go to "customize page" on the top right hand corner"
click on the "+" and add this resource, report writer -> resource from report writer.
*you might need to tweak the column size depending on the report
