I find out there are a lot of new status of interface in NPM 10.1 occasional.
Like the following ones. Does anybody know what kind of status those status represent?
unreachable is if a node that you defined as parent is down, therefore the child is considered unreachable and not down (to suppress multiple alerts).
this also applies to some automatic parent/child connections, like when a node is down, the applications are unreachable.
I would still like to know what Dormant, Testing, etc. all mean... if I filter for it in views it seems just like a mess, most of these tags dont filter for what they say they filter for
hehe7nic,
Many of these states are explained in the SolarWinds Orion NPM Administrator Guide. A list of states listed from worst to "best" is also provided in the section, "Status Icons and Identifiers > Status Indicators" of the SolarWinds Orion NPM Administrator Guide.
The main ones with which you might be concerned are as follows:
What's the difference between 'Unreachable' and 'Unknown'?
I want to know what Dormant, testing, too.
We do not actively use dormant or testing for NPM
I am also running NPM 10.1 and have an interface with "operational status" of Testing. The router reflect this interface as Up/Up. I understand that Solar Winds answer is that "We do not actively use dormant or testing for NPM" but for some reason this is the status that Solar Winds reflects for this interface.
Yes I have reviewed SolarWinds Orion NPM Administrator Guide and was unable to obtain an answer to my question.
~~ Many of these states are explained in the SolarWinds Orion NPM Administrator Guide. A list of states listed from worst to "best" is also provided in the section, "Status Icons and Identifiers > Status Indicators" of the SolarWinds Orion NPM Administrator Guide.
The "Status Icons and Identifiers > Status Indicators" of the SolarWinds Orion NPM Administrator Guide. does not have a listing for "Testing"
Can someone explain why this is occurring?
