I've created a poller to display the number of collisions on an interface in graph form but the scaling is ridiculous.
Is there anyway of either having the graph auto scale or manually change the scaling?
We should auto-scale, if not this is a bug. Let me send this over to Dev to verify and look into what is going on.
I've always wanted a way to configure the max scale on the graph. I know that gauges will let you configure a maximum, but not the UnDP graphs. Being able to set this, along with other properties of the graph (like units), would be pretty handy.
I also would love to be able to edit and configure the scale for the graphs created using the UnDP. Basically, if SolarWinds could implement the same or similiar graphing capabilities/flexibilities as I have with RRD I would be a happy fella!
I will log this as an enhancement request in the system
Hi, I'm also having a similar issue with a number UnDP graphs I'm creating for voltage, temperature, humidity, etc. It would be extremely useful to be able to manually set scale values for graphs or, even better, have some user accessible interface to scaling.cfg and then be able to manually assign settings to graphs from it.
For example, if I'm monitoring humidity and temperature (from an APC NetBotz) I get the following graphs:
The y-axes on both graphs are way out of range to be useful. I'd also rather they weren't normalised as I'd be able to glance at graphs from different devices (and, hence, different locations) and compare them quickly if they all used the same ranges.
So, any word on if this has made it into 10.0?
Any word on this? I have 9.5.1 and I don't see how to do this, so I guess it's not in there yet?
I would like to add my voice to the chorus asking for the ability to change X-axis and Y-axis scaling. My reason is simply to make comparisons between two date ranges easier to interpret by making scales the same instead of pegged to the data contained in the charts.
Was this ever implemented, this is causing me massive problems giving reports to end users.
