The web console settings in version 10.1 do not include an enable Advanced mode checkbox.
Where do I enable that in this version?
Can you elaborate what you mean here? Not following you.
http://www.solarwinds.com/NetPerfMon/SolarWinds/wwhelp/wwhimpl/js/html/wwhelp.htm
I want to add an otion on my menus to be able to click on a filtered view.
the manual entry above indicates I need Enhanced mode turned on to do this.
I cannot find that options where he manual sends me...
Is this in a diffrent place in 10.1 ?
Hi gmisner,
The link you posted only goes to the online guide table of contents. Can you point us to this in the PDF version of the guide? Need a page # or copy/paste.
http://www.solarwinds.com/support/Orion/docs/OrionNPMAdministratorGuide.pdf
Andy
Enabling Advanced ModeAdvanced Mode enables the creation of new views and provides additional resources that can be included in each view. The following steps enable Advanced Mode.To enable Advanced Mode:1. Log in to the web console as an administrator.2. Click Admin in the Views toolbar.3. Click Web Console Settings in the Settings grouping.4. Confirm that Allow Advanced Customization is set to Yes.5. If you are satisfied with the configuration of your view, click Submit.
Very strange. I think that might be a depricated feature that has not been reflected in the guide. What are you trying to accomplish? Is there a particular view you want to modify?
