I read somewhere that Orion NPNM running on a single polling engine can be expected to reliably monitor between 8000 and 10000 elements - regardless of the server hardware specifications.
However, I recently encountered an Orion server that seems to be violating this norm. Consider the following:
8605 Elements
957 Nodes
7104 Interfaces
544 Volumes
15821 Pollers
ICMP Polls per Sec - 30/172
SNMP Polls per Sec - 30/103
SNMP Node interval is 1 minute.
Notice that the poller is currently running at 30 polls per second for ICMP and SNMP, yet when the Polls Per Second Tuning app is run, it recommends adjusting to 172 and 103 polls per second respectively.
The CPU load and memory usage for this server are not remarkable, and all observed data graphs look normal in their granularity. So, how is it that this server is doing all of this at the default setting of 30 polls per second, especially if the SNMP node polling interval is 1 minute?
Any thoughts? Am I missing something that might explain this apparent anomoly?
