Hi All,
Whether solar winds has a self reporting portal ,where client can see only there devices and take the performance reports whenever there is a need .
Yes, create them a app level user name, and isolate their views using custom toolbars querying only data that they have access to.
We do this successfully. But keep in mind, a crafty user can click around and guess View ID's. This has been discussed in other threads.
Can someone share the docs to do this.
This should get you started:
Create a dashboard
I don't want to create dashboard ..Need some kind of reporting console to add a device and select the metrics type (similar to performance analysis )
Nothing exists out of the box allow end users to register their own systems for monitoring, it would be relatively simple to have a web dev put some kind of UI together using the API though if you were motivated.
