To create Username, password and enable password variables in NCM need I use Macros ?
what do you mean?
you have to configure your devices (routers) with a username and enable secret.
In NCM you only have to set the configured username and enable secret in you connection profile and then you can test your ssh-connection with the test button.
but this is explained in the admin guide. so i think you mean something different, right?
regards,
flo
I have a lot of Cisco routers , and I need create dozens login combinations (username, password and enable password),
so I think that I need use macros. I´m right ?
in macros you define user-defined variables.
you have to configure multiple Connection Profile in Settings->NCM-Settings->Manage Connection Profiles
The auto-detect profile is your default Profile which NCM tries to use if nothing is defined.
An other way I don'T know. Sorry.
In NCM v7.1 I didn´t found connection profiles option... :-(
in the WEB-Interface go to "Settings" then you get this page:
After that click on NCM-Setting and go on Global Device Default to Connection Profiles:
Hope you'll find it.
Kind regards,
Flo
