I've noticed similar issues with Cirrus since upgrading to V4. My node list seems to scroll down by a few nodes every five to ten seconds. If I just leave it sit, it will eventually scroll down to near the end of my node list.
Can you try disabling node monitoring / rediscovery by navigating to File > Settings > Node Monitoring? If this seems to resolve the performance issue, then your the problem you're experiencing is a known issue that we're working on resolving in SP1.
It would be really helpful for us if you would open a support ticket online so we can track all customers experiencing this issue and make sure you're the first to be notified (and potentially involved in testing the fix).
Yes...disabling the monitoring helped. I also reduced the # of configurations seen down to 10.BB
I also have the same problem - I basically leave node monitoring off permanently. We also run Orion, so I didn't consider it a big issue.
Dave.
V4 seems exceptionally slow when loading and selecting devices from the device list. We currently have a little less than 2,000 devices, node monitoring is disabled, and our server hardware should be more than suitable to handle the task.
One thing I've noticed is that Cirrus doesn't appear to be mutli-threaded. This is something that's a bit of a sticking point with me, as the Orion polling process is the same way. Don't get me wrong, I love SW products, but in this day and age, multiple processor systems with multiple cores is the norm, and the trend in server/data center management is to make the most use of available resources. While I understand the desire to focus on adding functionality, I also believe sufficient emphasis should be placed on application performance relative to current trends in deployed server hardware. This seems to be a key component that significantly hinders SW presence with regard to scalability in mid to large enterprise environments.
OK... I'm done whining now...
Definitely the same problem here... it's also running in the Mac version of MS RDP Client, to add to the slowness. It's no longer even responsive, it's like the application has completely frozen, and every 3-4 minutes, the file menu comes up (which is what I had clicked on earlier).
Cirrus is completely unusable at this point.
Is anyone still seeing this issue? I thought it was fixed but I went to us the server this morning and it has the same weird problem. The scroll bar is acting possessed moving up and down and the system is slow or unusable. I'm using 5.1.
BB
For those experiencing slowness issues with 4.x or earlier, try disabling node monitoring to see if that resolves your issue.
For those experiencing slowness issues with 5.1, please open a support ticket on these items and include a link to this thread. We have a fix slated for 5.1.1 that may resolve your issue and we may need your help in validating this fix resolves the issue you're experiencing.
Thanks in advanced for your help!
I opened a ticket. Case #77926
