So, what is the setting that will disable the session timeout in Orion v9?
It's controlled on a per-account basis. Go to the account management section of the website and edit the account that you want to have persistent sessions.
Under ...Admin-> Settings-> Web Console Settings see correct answer below
Yes, I know where to find the setting, but what value do I enter in the blank to disable the session timeout for a user account? Is it zero?
Thanks.
when you edit the account it will be a Yes or No.....
Ok, brain freeze here! I was looking for it in Web Console Settings and forgot about the option in the Account edit screen. Thanks.
