How are you setting up netflow for a T1 with out it bringing the utilization of the T1 to 90-100%? i have tried to monitor some our or locations accross T1s but it pegs out the utilization of the circuit.
Wow, we run Netflow on quite a few of our T1's with NetQoS and even in our doing testing with Orion NTA we've never had netflow be that much data. Were you monitoring a Layer-3 switch or switches across the link or something? Never heard that before!!
nope, just monitoring a data and voice vlan.
Wow, I'm at a loss, I know netflow data is higher bandwidth than SNMP at times depending on the flows, but that seems very excessive. We're talking like 1-3% on our T1 at the most...
How is your Netflow configured on the router, mostly interested in the commands with "flow" in them. ie: "show run | i flow"
The config looks like this:
interface Serial0/0/0.??? point-to-point description **Circuit ID is ???** ip address 0.0.0.0 255.255.255.252 ip flow ingress ip flow egress frame-relay interface-dlci ??? !ip flow-export source Serial0/0/0.???ip flow-export version 5ip flow-export destination 0.0.0.0 2055!
end
