Do we have any built in APIs in NPM, NCM, Traffic analyzer which could be used for integrating the tool with other tools/UIs?
Thanks & Regards,
Sumit
Can you provide more details on the use-case?
Hi Chris,
I am looking to develop a web portal which would be single point of login. It would provide the required interfaces/details from NPM, NCM etc based on the user credentials. For example if the user has the credential of a broadband user, based on his login he should be provided the filtered details of his usages/throughput etc. I don't want the user to see solarwind interfaces etc.
Regards,
This should be possible today through the Orion website using node limitations and account view limitations. In fact, we've got a lot of MSPs using Orion in this way. Have you already explored using Orion's included website for this purpose? If so, what specific use-cases are you not able to achieve?
I just want to make sure you're not investing in something we already do out of the box.
Thanks for the info Chris.
I wasn't aware that Orion website itself offers thode functionalities! I'll explore it further.
Could you please help me with some documentation on the same?
Cheers,
Sure, the Orion NCM docs can be found here: http://www.solarwinds.com/support/orionNCM/ncmDoc.aspx
See p.20 - Installing Orion NCM integration
In the same lines a specific use cases is; we are looking for a Northbound API for NPM, NCM and NTA to integrate with Higher level NMS such as HP ov or NetCool or NetAssure.
To cater to this need is there a standard northbound interface? If not what are the suggested method to interface with higher level NMS.
Prashant K
