When trying to upgrade NTA 3.5 from SL2000 to SLX I receive the error
"Database configuration failed: • Error while executing script- There is already an object named 'swsp_GetCBQoSConfigurationDetails' in the database."
Now I'm getting the error event "A license check failed. Orion version does not match NetFlow Traffic Analyzer version. Please contact SolarWinds to purchase an upgrade of NetFlow Traffic Analyzer" Any idea why or what I should do?
The issue is caused by the stored procedure getting created under a different schema than dbo, for example SolarWindsNPM if this is the user account used to connect to the database. To resolve this, you need to open the database in SQL Management Studio and run the following query: Alter SCHEMA dbo transfer SolarWindsNPM.swsp_GetCBQoSConfigurationDetails Just make sure to sub out SolarwindsNPM with the schema the procedure is associated with. To see this, go to Programmability > Stored procedures. This procedure will be at the end of the list. If there are others as well that do not have dbo as the schema, then run the above query and sub out for the schema to change. Once done, you can rerun the configuration wizard without error.
Did you upgrade NPM to SLX first?
Was the NTA SLX 2000 the RC test version?
I was running NTA 3.5 RC SL2000 and upgrading to SLX final release (assuming there were changes made between RC and RTM/gold).
Is the NPM an SL2000?
NPM is SlX
OK - sending some help your way.
Do you have a ticket # on this?
