Is there any way to show Down Nodes withot unmanaged devicies ?
Thanks.
Thanks a lot for all answers.
I was using a "View limitation", so I didn´t saw all down nodes.
Sorry for that.
Could you please be a bit more specific on what it is you are trying to do here, I am not sure I understand?
you can do this by creating a filter on the resource like this:
unmanaged = 0
I made this setting, but I´m not able to see nodes in "Node status is Down, One or more interfaces are in an Unknown state" condition.
Do you mean you aren't seeing the nodes status description next to the node name or that there are nodes missing from the list that you think should be there?
There are nodes missing from the list that should be there.
Do they appear in the list when you have no filter set?
