Has anyone ever used an NCM script to copy the IOS file from the SolarWinds server via TFTP to a Cisco Switch?
I am looking for an example to implement.
Thanks a mil
Yup, works a treat. Commands used differ depending on the model of switch though, which models are you looking to test?
Cisco 2950 switch
OK, you'll need to use the archive download-sw IOS command and make sure you have the relevant *.TAR image file in the \TFTP-Root directory of your Core server (the newer Cisco switches don't really like the old "copy tftp:<IOS filename.bin> flash:" commands - they use a subfolder in the flash: directory these days for the actual image file).
The following script will ask you for the full IOS TAR filename as a variable when you fire it off via the Config Change Template (note that the IOS versions I've listed below may not be your versions, I've just put these in so I don't have to switch windows when I'm updating an IOS cos' I'm a lazy sod):
/*.CHANGE_TEMPLATE_DESCRIPTION This template allows the upgrade of the IOS and associated web management tools on Cisco Catalyst switches..PLATFORM_DESCRIPTION This runs on Cisco IOS devices..PARAMETER_LABEL @ContextNode NCM Node.PARAMETER_DESCRIPTION @ContextNode The node the template will operate on. All templates require this by default. The target node is selected during the first part of the wizard so it will not be available for selection when defining values of variables..PARAMETER_LABEL @IOS_FILENAME The File Name of the new IOS Version..PARAMETER_DESCRIPTION @IOS_FILENAME This should be a valid Cisco IOS File. No spaces are allowed, a script will not be generated for a Cisco IOS Filename that includes a space. Current IOS versions held on the server are: 2960: c2960-lanbasek9-tar.122-58.SE2.tar 3560: c3560-ipbaselmk9-tar.122-55.SE5.tar 3560G: c3560-ipbasek9-tar.122-55.SE5.tar 3750v1: c3750-ipbaselmk9-tar.122-55.SE4.tar 3750v2: c3750-ipbasek9-tar.122-58.SE2.tar*/script UpgradeIOS ( NCM.Nodes @ContextNode, string @IOS_FILENAME ){string @CommandLine = 'archive download-sw /overwrite tftp://$@{StorageAddress}/' + @IOS_FILENAMEif (@IOS_FILENAME contains ' '){}else{ foreach ( @node in @ContextNode ) { if ( @node.Vendor == 'Cisco' ) { CLI { @CommandLine } } }}}
NCM Node
script UpgradeIOS (
else
CLI
@CommandLine
If you want the switch to reload and take the new image immediately then you can add the /reload variable to the command line - I like to check that the IOS has uploaded successfully first to be honest then reload the switch early in the morning etc.
Regards,
John
John,
that is an excellent and very educative example of many different things
- how to create config change templates (CCT)
- how to use variables within CCTs
- how to use macros defined in device template within CCTs
Why don't you upload this template to the Content Exchange?
I'm going to add reference to your post to the blog post I've created recently: .
Jiri
Hi John,
can you confirm if this is still valid, because I'm receiving too many error while running the script
Script should work fine as long as it's not an IOS-XE install; can you tell me what errors you are seeing?
