After applying Hotfix 6 in Orion(NPM 11.5.2), active alerts panel is blank.
Why not upgrade to 11.5.3 it has hot fix 6 already integrated.
https://support.solarwinds.com/Success_Center/Network_Performance_Monitor_(NPM)/NPM_11.5.3_Release_Notes
you can try to force any existing alert and see if there is something wrong...also log files would help..
I've seen this before try rebuilding the website.
Please follow the below procedure on how to recreate the website.
1. Stop all Orion Services using Orion Service Manager
2. Open IIS and take a screenshot of your Solarwind's site bindings.
3. Open C:\Inetpub
4. Rename the Solarwinds folder to Solarwinds_OLD, if showing locked stop the WorldWide Web Publishing Service.
5. Open IIS
6. Delete the Solarwinds Orion Website
** Please note that all settings are stored in the database so by deleting the website you will not lose any data
7. Open the Orion Configuration wizard
8. Run the website portion of the Configuration Wizard
9. This will create a new website for you.
10. Check the site bindings in IIS to ensure they match the screenshot you took.
Had the same issue.
Were you able to resolve your issue?
Not yet. I do have a case open as we have 7 NPM's to upgrade.
Any updates regarding this?
Before going to any drastic measures I'd at least just rerun the config tool and reconfigure again without changing anything include the web site. If I'm not mistaken I had to do this after HF6 as well to get everything kosher again. This will recheck everything and rebuild the website again. If something is out of sorts this often gets it sorted again. You don't need to enter any changes just let the config tool do a complete reconfiguration.
I'm on: Orion Platform 2015.1.2, NCM 7.3.2, WPM 2.2.0, NPM 11.5.2, IVIM 2.1.0, QoE 2.0, SAM 6.1.1, NTA 4.1.0
I'm going to be installing HF6 tomorrow so I was just curious if there were any issues that popped up. Did any other quirks pop up for you ecklerwr1?
While true I usually stay at least one version back from the latest... call me paranoid.
Yep, I am the same way. I usually like a version to be out 2-3 months before I upgrade so that any quirks and bugs are figured out.
It's kept me out of some pretty serious problems more than once too!
