Does the API support a method to force a manual poll on a node?
The url should be https://SERVERNAME:17778/SolarWinds/InformationService/v3/Json/Invoke/Orion.Nodes/PollNow
And the POST body should be:
['N:100']
Yes. You can invoke the verb "Orion.Nodes.PollNow" to do this. It expects one argument, a NetObjectID. For a node, that looks like "N:123" where 123 is the NodeID value.
I am trying to use it in a POST e.g. (NodeID: 100)
https://SERVERNAME:17778/SolarWinds/InformationService/v3/Json/Invoke/Orion.Nodes/Poll.Now/N100
I am trying it using POSTMAN with Basic Auth
Receiving a 500 Internal Server Error.
"Expecting state 'Element'.. Encountered 'Text' with name '', namespace ''. "
I think I have not formatted the URL correctly.
Hi @tdanner,I'm getting an error stating:
"Encountered unexpected character '''."
I'm not sure what I'm doing wrong
Here's how I tried it via Postman:
Here's trying it in PowerShell ISE:
Do you know what I'm doing incorrectly?
JSON strings use double-quote delimiters.
From PowerShell you can also build up your body using powershell objects and use the ConvertTo-Json cmdlet to handle the json syntax for you. Like this:
$args = @( 'N:1261' )
$json = ConvertTo-Json $args
