hi
i have configured Cisco IPS and LEM as per manual but i try to add Cisco IPS it didnt get add on LEM and get following message on LEM monitor window
javax.net.ssl.SSLHandshakeException: Remote host closed connection during handshake
What version is the Cisco IPS running, and what version is the LEM?
Cisco IPS 7.0 & LEM Trail version 6.2.1 , running trail version because if i get successful in getting CISCO IPS logs to LEM than will proceed to Purchase this LEM.
Can you send over a screenshot of the connector you're using for the LEM to connect to Cisco and the config of that connector?
i saw an issue that when i connect IPS with IPS Manager after apply credentials on IPS manager it prompt me to accept certificate that was generated by IPS , is there any way to accept IPS certificate in LEM.
need help !
