Is there some way to do this:
http://www.simple-talk.com/sysadmin/exchange/reporting-on-mobile-device-activity-using-exchange-2007-activesync-logs/
Using APM?
Ok, since no one responded to my initial question, let me ask - is anyone monitoring the types of mobile devices that connect to their exchange servers?
Hi Jspanitz--
I've marked this for the PM to try and get you an answer.
M
Thank you Marie! It's great to have people like you keep an eye on the forum.
I'd like to ask if a PM ever reviewed this. Is there a way to do this now? If not, can we ask it be added as a feature request?
mhh,
with a graph i believe this is not possible natively in APM.
if its good enough for you to have each device on a separate graph and you could use a script to run that powershell script and then instead of exporting the data into sql (which you can do as well if you like) you can give one of these values back from powershell to the initial script, APM would then just graph based on the return value.
thats the only way I can think of right now without using external reporting tools in which case you probably wont even need APM for it.
