Can anybody tell me the comparison between NPM 10.3v and 10.5v. Thanks in advance.
Regards,
Kiran Javed
After upgrading system from 10.3 to 10.5 how shall we do verification???
Hi Kiran,
What verification do you mean? What exactly do you want to compare?
Cheers,
Pavel
Verification that upgraded SolarWinds installation is operational or not???
When you log into the Web Console, look at the very bottom, and you should see that the version of NPM is updated to the current, as well as the Core version as per release notes.
Orion Platform 2013.1.0
NPM 10.5
The rest is just to see if you are missing statistics, or that pages are erroring out. If anything of that sort is not happening, it should be fine.
HTH.
what possible problems might be during upgradation?? I want to prepare myself completely before upgradation so that i can handle the situation in case of any problem during upgradation. So kindly help me if any one knows. I'll be thankful.
Kiran,
There are too many possibilities of what might go wrong. Also, you might not have any issues on upgrading.
To be safe, just backup the Orion database and keep it safe. Most of your settings and statistics are stored within it.
The \Reports folder (or if NCM is in the picture, maybe custom device templates that you have made manually) needs to be backed up from the server separately.
If you need help, just contact Support, and we will be happy to help you out - SolarWinds Contact Us
