Hello community,do I need to configure a FS logga report so that the alarming will work?
Regards
For alerting you need make sure you have logga enabled for AD or File servers and then enable it in alerts.
https://documentation.solarwinds.com/en/Success_Center/ARM/Content/alerts.htm
I know, but do I have to configure a FS logga report to make the alarming work?
the documentation only mentions that the logga has to be enabled so i would assume that specifying reports is not necessary but i can not guarantee. why do you not just try it out?
FS Logga does not need a configured report for alerts. Just turn it on and set the alert sensor to active.
Then you can configure an alert.
I tried and it seems that their has to be a report configured to get the alarming work.But I would like the Solarwiinds could confirm that.
in that case i would recommend contacting support, it is unlikely you will get an official answer here.
Problem solved. Configuration error.
