What are the credentials needed to set up the virtualization manager integration in orion. Is that just the web page log in , appliance password or something else?
it is the account used to access the appliance. The account should also have vCenter permissions is connecting to a vSenvironmentrnment.
"The account should also have vCenter permissions is connecting to a vSenvironmentrnment."
It woiuld seem to me that this account is just the appliance user/password independent of Vcenter creds.
My VMan appliance has its own user/pass that we enter in the integration page, and it tests OK, just using the built in Admin account.
This account is not related to Vcenter so can you can you clarify?
I'm having all sorts of issues getting VMan data to Orion.
All of my data is in VMan fine, but VMan data is not getting to Orion at all.
Thanks.
Here is the way I have things set up. It sounds like you have the same setup unless I'm missing something, so I'm not sure if I'm helping, but just in case.
VMAN:
We have an account that has access to connect to the vCenters and pull in the data.
We also have the admin password for VMAN itself.
Orion:
We use admin username / password to build the integration between VMAN and Orion. This connects over port 443.
For the polling, we assign the account that has access to connect to the vCenters. This is set under Virtualization Settings for each vCenter.
This is how I have it setup. I'm getting all data but storage and other misc data now. This worked perfectly for 6.0 before we moved to 6.5.
VMan sees all. But Orion console does not. Frustrating.
That might be the difference. We haven't upgraded yet. Still at 5.5
