People,
As per https://documentation.solarwinds.com/en/success_center/orionplatform/Content/System_Requirements/Orion_Platform_2020-2_system_requirements.htm
The SQL database for the Polling Engine must be separately located in two different VMs.
May I know what are the steps that I can follow to migrate the Solarwinds Polling Engine SQL Server to another VMs running SQL server?
Thank you in advance.
hi, @sum_giais Thank you for the confirmation.
After the SQL server DB .MDF and .LDF has been migrated off to another VM, can I completely uninstall any or all SQL server components in the main polling engine?
I would disable them first and see what happens.
