Is it possible to add the NCM to two different Orion servers? We have EOC and two different Orion deployments, but all of the nodes are in one single NCM deployment. Can I run the intergration tool on both Orion deployments?
Although this scenario was not specifically tested, I think it should work.
I need the opposite. I have multiple NCM servers and 1 Orion system. So right now I can only point to one of the NCM servers.BB
I will be testing this later this afternoon. BB, not sure about that one, seems a little more involved. They need an EOC or NCM
Perhaps...but facts are I think alot of customers would be in this situation like me. I have ideas like maybe you can define any NCM server to Orion but somehow identify which node uses which NCM. Maybe a custom property value that u select for each node.
Eventually I see where you go into Orion, add a node and in the same manner where you can assign it to a poller you can assign it to a specific NCM server.
BB
Ok that worked, so my next question is how about in EOC???
