Is there a way to count the nodes in a report and put the total count in the header? or footer?
With the new web-based reports in 10.6 you can summarize table information to produce a row count. EX:
That’s to easy! Do you know how to do the same thing in 10.5?
Robin Spitzer
CNE, CCNA, SFB
Network and Engineering
Network Technician II
Fresno Unified School District
Room B38
2309 Tulare St
Fresno, CA 93721
Desk (559) 457-6255
Cell (559) 260-0886
Office (559) 457-2540
E-Mail: Robin.Spitzer@fresnounified.org<mailto:Robin.Spitzer@fresnounified.org>
It won't be as easy to format nicely, but you can summarize similar to:
I truly appreciate your help. I think I asked the question incorrectly.
When looking at this report, I need to know how many row’s there are. So, that at a glance, you would know if all the nodes have been included in the report. (I have not finished adding all the nodes yet, but there should be approx. 110 or so…
Got it- that would be difficult to do within the construct of the old report writer without resorting to custom SQL, and one of the reasons why we made sure to have multiple resources available in new reports in 10.6. If you have a maintenance window to upgrade in the near future, it would definitely make your life easier.
