Is there any way to add asset inventory via SWIS? Like using create or invoke methods. If possible, can you give an example?
I try this code but got that error, "Entity Orion.AssetInventory.Polling does not contain any key properties. Parameter name: entityType"
swis.Create("Orion.AssetInventory.Polling", new PropertyBag
{"EntityType", "Orion.AssetInventory.Polling"},
{"NodeID", pai.NodeID},
{"PollingDescriptionName", pai.PollingDescriptionName}
Programmatically configuring Asset Inventory is not supported right now. We have an internal ticket to add it as a feature. The ticket number is 348041 if you want to check on status in the future.
Thanks for reply madhavan,
I will wait to supporting this feature. I hope it will be asap.
Was there ever any update to this ticket?
Did internal ticket number 348041 ever see the light of day?
Sooooo is this supported in 2018 ?
No, it is not.
Still not on the radar for 2019?
From what I can tell, this is not supported yet. The internal ticket number is now SAM-7966 instead of 348041.
As of the 2020.2 release there are PollNow, EnablePollingForNodes, and DisablePollingForNodes verbs on Orion.AssetInventory.Polling:
http://solarwinds.github.io/OrionSDK/2020.2/schema/Orion.AssetInventory.Polling.html
