I need a little help with syntax on this widget. I am trying to narrow the display down to only show Virtual Machines that "CDC" in the hostname. Please look at the screen shot to see the properties I have available.
We have a resource that filters this way under Filter Nodes (SQL):
Caption Like 'CDC*'
Maybe something like that?
I think @holleyc77 wants the CDC anywhere in the name, but @wilder's example gets it done if its always a prefix. If needed anywhere in the name it would look like:
Caption Like '*CDC*'
If you need to figure out if its virtualas well, it may not have that condition ready for you. Stringing conditions can be done with 'and' but if you need a more complicated filter with infomraiton not built in, we may want to move to the Custom Query or Custom Table widgets @mesverrum has created and collected lots of widget replacements as well over at https://github.com/Mesverrum/MyPublicWork .
But you likely don't need alot to do what you want. I may have overlooked it, but what widget are you trying to replace? We can likely whip up a SWQL statement to assist if you want the Custom Query widget to help you.
Hi @jm_sysadmin
This is for the "Top XX Hosts by CPU Load" widget. You are correct, I want to filter out of all my servers the server that have "CDC" in the name.
Would I use the HostName property? What would the syntax be?
If caption doesn't work try SysName , use 'not like ' to remove from th list
SysName not like '*CDC*'
@jm_sysadmin So SysName or Caption are not one of the options for the widget. I added a image of what is allowed. Thanks
