Does the Real-Time NetFlow Analyzer have support for any flow sampling other than NetFlow? ie. sFlow, JFlow, etc?
Found this thread:
Mark Wiggans said 2.5 years ago that it is possible in a future release, but......
It does support sflow
Well, then I seem to be having an issue. haha I have setup an Extreme switch to export flow data to an workstation, the Real-Time tool is up, I have added the switch, I see the interfaces and I see traffic stats in the list for the interface I want to watch. When I click Start Flow Capture I get an error stating that NetFlow is not detected on the selected interface. Wireshark confirms I have the sFlow packets coming to this workstation.
It's got to be sflow v5
Packet info from WireShark shows v5...
Hi There---
Have you looked at the KB article that addresses flow template fields required for NTA? Take a look and see if that helps. If not, I'd open a support ticket on this.
M
The output IfIndex =0 is probably the issue.
