Hello.
I'm evaluating version 9.2.1 because I need to modify the message when it arrives adding a string, than forwards to another syslog server using the original IP source address.
Many thanks.
Regards.
Andrea
Do you want to remove the original message and insert a new message and then forward or keep the original message and insert another line of text?
I need to insert a string than forward but I need a licensed version to run a script!
With a licensed Kiwi version 8 I can run script and forward. Anyway, with the "Retain the original source address" option checked, the receiving syslog server doesn't report the correct source IP address.
For 9.2.1 are you running the free version or the 30 day evaluation version. With the 30 day evaluation, you should be able to do the same as you did in v8. Try this and let me know if you see the same behavior as described in v8.
Now I'm running 9.2.1 evaluation version. I have the same problem.
Syslog messages arrive to syslog server with incorrect IP address 192.168.20.1
Nov 10 22:49:19 192.168.20.1 Original Address=192.168.20.129 %HP-5-VIRTUAL: VCEFXTW212100GK
Any ideas?
Thanks.
