I'm curious what the recommended max number of "Log Entries" are in one Log Analyzer Rule? How many strings are too many?
That is an interesting question ... I will have to ask the team if there is any limit or a number that is reasonable to keep it under.
I should have asked... Do you already have a rule with quite a lot of them that isn't working or is the question more theoretical in nature?
I have a rule with about 75 different strings in them, and the website freezes when trying to load it, but eventually will load everything. I also have a support case open for this but after 2 days, no one has touched it yet. One rule i need to create has about 399 entries to look for, and in creating one that needed approx 200, i broke it out in chunks of 50 when 70+ seemed unmanageable.
Can you send me the ticket number so I can check on the progress of the case?
Can you be a bit more specific about the nature of your rule? If there are 400 variations on the log message is that really all tracking back to a single type of issue or is this lots of different situations?
Ticket 00439036. So far they just requested more time to look into it.
