I can't tell from the examples, or the documentation. How do you execute the Discoverinterfacesonnode and Addinterfacestonode verbs using the Perl SDK? I don't know if I'm just missing it and it's somewhere obvious.
Can you show an example?
The Orion SDK 1.5 Perl client doesn't execute the Invoke call correctly. However, please take a look at the thread: SDK 1.5 invoke with Perl ? It contains a link to a fixed version of the client with the sample script supplemented with a fragment showing its usage.
Hope this helps.
Hey Tom,
Thanks for the info. I went to that page previously, and I had downloaded it (But I did re-download it, to be certain.)
In the sample, I do see an invoke operation for Unmanage (which I'll need later) But is there an example of a DiscoverInterfacesOnNode and AddInterfacesToNode somewhere? I don't see it in the zip that was attached, nor in any other doc I can find.
Here is what I use : my $interfacesIdResult = $swis->Invoke("Orion.NPM.Interfaces", "DiscoverInterfacesOnNode", [$nodeID]);
But, there is a 60 seconds timeout, hardcoded. I'm unable to test the result of that, but calling it this way should work.
Hey, thanks for this example.
When I used it, I got the following error:
2012-08-03 16:42:19,005 [215] ERROR SolarWinds.InformationService.Core.InformationService - Exception caught in method Invoke
SolarWinds.InformationService.Verb.VerbExecutorException: Verb Orion.NPM.Interfaces.DiscoverInterfacesOnNode: Not found
This would lead me to believe that somehow it's the older version of the API that doesn't have this new Discover feature. But when I run the same command inside of the SWQL studio, it works fine, so I know that the backend is the correct version.
Anyone have any ideas why I'd get this? I also carefully updated the pm to the updated version, so that should also be fine there...
That verb is only available in SWISv3. You will need to use a URL like this:
https://$hostname:17778/SolarWinds/InformationService/v3/OrionBasic
