The description says that the new Threat Hunters and Rage Against the Virtual Machine shirts come in sizes up to 2XL, but I can only pick XL in the shopping dialogue. Which system is wrong?
The description is correct, in that we order sizes up to 2XL; however, once you get into the "select size" option, you will be presented with only the sizes we have left in stock. Does that make sense? These two t-shirts are remaining shirts from past campaigns so we may not have all sizes available anymore.
If I have something in my cart, can I cancel it and get my points back, then? I'm about 35 pounds beyond an XL.
We would need to delete it at the database level and then work with DanielleH and/or maria.bungau to see about getting a refund of your points. Is this something you need to do? Have you checked out or just added the item to your cart?
Just sitting in the cart. I don't see a way to remove an item.
OK, let me work on getting your cart cleared out. I've got a few other issues I'm tackling at the moment, but I promise I will get this done before the EOD. :-)
I also noticed that when you select a shirt and then the size, if you "keep shopping" when you get back to the cart you need to re-select the size of the shirt. Seems like it is not retaining the data. Of course there may be a "retain" or "not retain" value based on the level of stock available...either that or the cookie monster has eaten the cookie.
curtisi, I just sent you a DM.
