I saw web page problems after upgrading to v8.1 - specifically with the Alerts, Reports, Syslog and Events pages.
After I tried this hotfix update those pages started working properly - however it broke ALL the other pages (like top 10, node details etc)The error I get is -
"Microsoft VBScript compilation error '800a0400'
Expected statement
/NetPerfMon/View.asp, line 3 "
My server is using Port 80 - however it has 2 NIC cards (on different un-connected subnets) and the server is set to run on [all unassigned].
Anything I can do to get this working again?Thanks, Sean
Actually - scratch that - I realised I hadn't upgraded the NetFlow to v2.1 - after that upgrade everything seems to work now - even without the hotfix installed.Sean
Denny,
Shouldn't this be done on your Hot Stand-by server as well?
Just checking...
Denny, Shouldn't this be done on your Hot Stand-by server as well?Just checking...
Yes, you should hotfix everything with a web server.
If after installing this hotfix, you run the congif wizard, and it re-creates the website, will it overwrite the new netperfmon.asp file with the old one that didn't work except on port 80?
Yes. You would have to re-apply the hotfix. We're working on a more permanent solution.
Even with the website hotfix, the Traps.asp page still doesn't work. I get the following error:
/NetPerfMon/Traps.asp, line 3
#@~^ugIAAA==7@#@&7GksPKMlad@#@&d9ksPK.bxYjnDkkW @#@&dGksP)VsGSZs+m.@#@&d@#@&iI+d2Kxd+c3XwrM+kP',!@#@&dU+s+1Y n(PJgnYh+D6\Gxr@#@&d#+.r6XJWTrxiJijAIJ@#@&in.k Oj+.kkKx'"+$;+kYcJhDrUDl4^nRXJ#@#@&7@#@&dzVsWA/^+CD,xPg+OKD0\G R/EM.xOzm1WE Yc)V^WA27+UO;V+m.@#@&d?O~KMla/~'~jD-+M ZM+COr4%n1YcJ}.bWUgnt+(R:.la/E#@#@&7PMlwk b^VWS/s+mD,'~bssKh/VCD@#@&7PMlwd U+s+1Ot+dklT+/@#@&i@#@&i?VkaCP\dP',ol^/+@#@&7?VmOP/Ck+~j1C/`]n$E+dOvJ9lDCwW.slDJ#*P@#@&diZC/PEptSJB~J;?.rS~J;fwJSPEPA(PJB~J:(PEBPJ])qJSPrptSE@#@&iddA\UYkR9WG+OCbVI2WMY@#@&77mm/PE2p/ASE~,E2oZ3JdJ~~EoSjJ@#@&id7qDbY+A61nVhlL+@#@&77;l/~2^/+@#@&7diMkO+uPtSKlTn@#@&d3U9P?nsmO@#@&7@#@&7&0,S+ `h.k Y#+M/rG #',TP:t+ ~KDbxD.nDdrKx~',]+$EndD`JK.bxOl(sJb@#@&98EAAA==^#~@^
The traps.asp file in C:\Inetpub\SolarWinds\NetPerfMon appears to contain a bunch of garbage text in it.
Please advise.
The traps.asp problem is one we have found with upgrades. The work-around is to go into c:\program files\solarwinds\orion and delete the file TrapServer-Website.zip. Then rerun the website portion of the configuration wizard.
This is a file we left sitting around by accident- it should be deleted on upgrade. It does not need to be there anymore and is causing your problem with the Traps.asp page. We will fix this in the next release.
