Hi, I need to download Orion NPM 9.1 SP5 but the links which I found on this site don't work:
ftp://ftp.solarwinds.com/Orion/ServicePack/Orion9.1-SP1.zip ftp://ftp.solarwinds.com/Orion/ServicePack/Orion9.1-SP2.zipftp://ftp.solarwinds.com/Orion/ServicePack/Orion9.1-SP3.zipftp://ftp.solarwinds.com/Orion/ServicePack/Orion9.1-SP4.zipftp://ftp.solarwinds.com/Orion/ServicePack/Orion9.1-SP5.zip
Please Help me on this.
Thanks in advance.
Please contact support to get the correct links
Does anyone has the correct links?
As I indicated above, you will need to contact support to get the correct links. As long as you are under active maintenance, this should not be a problem
Sir, I can't figure out why service pack for a software which is common, is needed for support contact. These days every single software gives this updates to every one!
Let explain my situation. I am using a trial version of Orion NPM 9.1 and want test for upgrading to 9.5. For this purpose as your documentation I need to be at least Orion NPM 9.1 SP5 to be able upgrade to Orion NPM 9.5.
So as I testing trial version I cannot ask support for service pack. So please give me a way to obtain a suitable service pack.
Thank you in advance.
So 9.1 came out in Oct 2008. Just how are you still running a trial version?
Dave.
